Old 2-Oct-2010, 4:07 PM   #31
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
Originally Posted by Billiam View Post
I'd try the MXU59 first because it costs less than the 91XG. Both should give you every UHF channel from WAZE to WTVW.
I'd then try the YA-1713 in place of the Stacker for the VHF channels. If this configuration does not work then it seems to me there may be some kind of environmental problem in the vicinity that is impacting your signals.
Amp wise I'd go back to the one you were using originally because it gave you better performance. See if you can return the HDP-269 for a refund. Clearly you need the additional gain that the 8700 offers.
Sorry, but that is completely wrong advice: If the preamp is properly installed, it should NOT adversely affect affect your signal strengths or TV reception: Digital signals need very little gain to be viable: more gain is NOT the answer. A preamplifier is only necessary to cover line and splitting losses in an antenna system: more than that is not only superfluous, but can cause other reception problems like overload.
I suspect that your issue comes from your ANTENNA, and not your preamp. The advice about it MX-59 is also wrong: it is NOT as good an antenna as the XG-91, and is almost as expensive. Solid Signal sells the XG-91 for $53.00. it sells the MX-59 for $46.00.
DUMP the Stacker and use a combination of an Winegard YA-1713 and an AntennasDirect XG-91, combine the signals using a Pico-Macom UVSJ, then go into the HDP-269.
Aim the antennas as you were directed, and your problem will be solved...
