Old 19-Jan-2010, 4:54 PM   #7
zuiko
All the channels are within 1 degree of each other so that isn't a problem. It finds them all (and then some) so that isn't a problem either. The issue I have is that everything will be fine for 30 minutes then the signal will just randomly break up or get lost. If I change to another channel and then back it will often fix it. Seems to be an issue with all channels. So maybe the aiming is borderline (but I am well within 15 degrees... at most I am off 5 degrees). Maybe it is the tuner on the TV... it is obviously not a high end model since it doesn't even have a signal strength meter.
zuiko is offline   Reply With Quote
