Old 3-Sep-2012, 3:17 PM   #5
ALL questions and answers about broadcast tv reception and More.
The following is a Teleview - Recommendation for Digital Broadcast Tv Reception.
Above the roof install a Clear Stream 2 Complete UHF/VHF antenna aimd at about 160 degree magnetic compass direction. http://www.antennasdirect.com/store/...VHF-Combo.html.
For 1 tv connected use no splitter.
For 2 Tv's connected use common simple 2 way splitter.
____________________________________________________
These Digital Tv stations/channels will be received.
WXMI REAL Digital UHF channel 19 , virtual number (17.1-2-3) Fox and Antenna Tv and This Tv.
WOOD-DT REAL Digital VHF channel 07 , virtual number (8.1-2-3) NBC and MyNetwork and Local Weather.
WWMT REAL Digital VHF channel 08 , virtual number (3.1-2) CBS and CW.
WOTV REAL Digital channel UHF 20 , virtual number (41.1-2) ABC and The Cool Tv.
WLLA-DT REAL Digital UHF channel 45 , virtual number (64.1-2-3) My Family Tv , RTV= Retro Tv Network , Family Network.
WOLP-CD REAL Digital UHF channel 41 , virtual number (27.1-2) MyNetwork and Local Weather.
WGVU-TV REAL Digital VHF channel 11 , virtual number (35.1-2-3) PBS.
WZPX-DT REAL Digital UHF channel 44 , virtual number (43.1-2-3) ION Tv.
WZZM REAL Digital VHF channel 13 ,virtual number (13.1-2) ABC and Local Weather.
__________
WXSP is the same as WOLP.
__________
WUHQ is Daystar Religion , WTLJ is Religion , these 2 Tv stations are to the back of antenna (north west) and are strong signal strength and will most likely be received through the reflector screen of the antenna , if not and you will like to receive them , then remove the reflector screen of the antenna.
Here are some roof top antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.antennasdirect.com , http://www.amazon.com.
