Thread: Junior Member
Old 2-Oct-2010, 3:42 PM   #12
mizzou
Thanks guys, I have some work to do! Yea, this is what I like most. I appreciate the idea of seeing how the signal might be, by setting an antenna up before mounting. I am also thinking of placing the pole/post to the surface. Checking out a signal will require buying an antenna or two. Is there a source that allows returning product if the purchased items do not work (i.e. YA-6713 or C5 & XG-42)? Is buying direct to Channel Master, Winegard, etc the way?
Thank you again, mizzou
mizzou is offline   Reply With Quote
