Old 3-Sep-2012, 8:07 AM   #13
Eroc
Good question. It should be cable tv leakage, but, TWC does not have NFL network or Redzone and therefore does not broadcast these channels period. These are showing up in my guide, however, I cannot actually view these. They are encrypted.
There definitely could be a leak somewhere and I will try to figure that out.
First, I am going to disconnect the incoming cable line tomorrow, move it away from the antenna coax and see what happens. If it is a leakage inside my house this should take care of it, right? If the problem persists then it must be outside, whatever it is.
I will then call the cable company.
Thanks again.
Eroc is offline   Reply With Quote
