Old 3-Sep-2012, 2:30 AM   #4
thom
The reason I asked about the power supply (amplifier) is this: http://www.amazon.com/review/R19573D...re=electronics
(last paragraph)
Post a link to a new report with 15 ft elevation so we know what we're looking at.
Have you tried re-orienting the antenna at all?
The trouble with this style of antenna is you risk overamplifying the strong signals of which you have some. A decent passive antenna might be a better choice for you. If you were attracted to the RCA because of the small form factor, you might find something like a DB2e (or DB4e) with a dipole add-on palatable.
http://www.solidsignal.com/pview.asp...-Antenna-(DB2E)
http://www.solidsignal.com/pview.asp...sku=5374800141
http://www.antennasdirect.com/store/...-Assembly.html
If you can handle a screw driver you can take apart the reflector assembly and put the dipole on the back of the DBe (screw hole is already there). It's a compact but potent combination, and the dipole is very effective on 11 and 13. I'm pulling 11 and 13 from almost 100 miles away with the exact same dipole (though I wouldn't have believed it if I hadn't seen it myself).
However, that's all speculative until you post an updated report.
thom is offline   Reply With Quote
