Old 2-Oct-2010, 8:57 AM   #4
John Candle
Tv Reception
If by high tension lines you mean the big high power transmission lines , it's a connect up the antenna and see. The greater the distance between the lines and the antenna the better. Ground the antenna pole that the antenna is mounted on and ground the coax cable. This will reduce interference. Grounding clamps for the antenna pole and coax grounding blocks and ground wire are common at places like home depot and etc. .
