Old 2-Sep-2012, 2:35 AM   #3
ALL questions and answers about broadcast tv reception and More.
The following is a Teleview - Recommendation for Broadcast Tv Reception.
The Local Digital Tv stations/channels , Are strong signal strength and will most likely be received by the HD7084P antenna even though the HD7084P is not aimed at them.
The following is a list of the locals.
WKYU-DT channel18 PBS
WKUT-LD Channel 25 Budd Broadcasting Inc. ??
WBKO-DT channel 13 ABC and FOX and Jewelry Tv and CW+.
WKGB-DT channel 48 PBS.
WPBM-CD channel 46 Family Net , Religion.
WNKY-DT channel 16 Local NBC and Local CBS.
If some locals are not received and you will like to receive them , install a ANT751 antenna above the roof aimed at about 368 degree magnetic compass direction.
Use no preamp with the ANT751.
For 2 Tv's connected use a common simple 2 way splitter.
For 3 Tv's connected use a common simple 3 way splitter.
The 2 antennas Will Not be connected together on to 1 coax.
The 2 antennas Will Have Separate coax all the way to the Tv/s location where a Remote control A/B coax antenna switch will connect to the to separate coaxes and the hand held remote control will change antennas.
http://www.mcmelectronics.com , #32-4425 , or , http://www.radioshack.com , #15-1968 .
________________________
For the locals you can try a Trek HDTVi , indoor antenna aimed at about 368 degree magnetic compass direction.
