Old 1-Sep-2012, 11:38 PM   #2
The following is a Teleview - Recommendation for Broadcast Tv Reception.
Here is a short list of the Digital Tv stations/channels of the south west group of Tv stations , NBC , CBS , ABC , PBS , FOX , CW , MyNetwork , This Tv , The COOL Tv , America One , ION Tv , The Country Network , Live Well Network.
What looks like is going to happen is , WTVF Digital low band channel 5 (CBS and THIS TV) is going to change to UHF Digital channel 25 , www.rabbitears.info/tvq.php?request=items&call=WTVF-DR.
And WMB will begin transmitting on Digital VHF low band channel 5 , http://transition.fcc.gov/fcc-bin/tv...0&facid=190683.
___________________________
To cover all changes no matter which way changes go.
Above the roof install a Winegard HD7084P all channels antenna with a antennas direct CPA-19 preamp aimed at about 210 degree magnetic compass direction.
The HD7084P antenna receives all the Digital Tv channels.
UHF band channels 14 thru 51.
Buy the HFS splitters at , http://www.hollandelectronics.com , or at , http://www.solidsignal.com.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com.
As always trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions.
It is best to install the HD7084P antenna at a location where there is the least amount to no amount of obstructions in the directions of reception.
