"indoor long-range antenna" is an oxymoron.
However, you are in fine circumstances. You have many powerful stations close by on one heading.
If you want something simple and don't want to mess with an antenna in the attic or on the roof, The ClearStream can do the job. It's not explicitly a VHF antenna, but it will pull in the stronger VHF stations you have.
This does assume that you have no obstructions nearby (buildings, trees), no aluminum siding, and your home doesn't have steel framing.
PS I'd be a little suspicious of the $9 one on Amazon, though. These should be around $35.
