Old 2-Oct-2010, 4:03 AM   #1
baron
Help with antenna setup in MD
Hi everyone,
I've done some research already, but was wondering if I could get some help from the forum regarding antenna setup. There are really helpful and informative threads here.
What I am trying to do is to get as many channels OTA as possible. I live b/w Baltimore and Washington and the suburbs of MD, zip code 21076. Here is the signal analysis:
http://www.tvfool.com/?option=com_wr...a36221603d6240
Right now, only indoor bunny ears are setup. I intend to get roof top antenna once I find the right one. Using TVFool and antenna web, I know that most of my channels from baltimore are about 32 degrees yellow, and most of my washington channels are about 244 degrees blue. Is there an antenna that could grab the channels from both cities without going the double antenna route? If I purchased something like hd7695p and pointed it towards washington, would it also be able to pick up baltimore channels as well even though the polar patterns for this antenna is highly directional?
Thanks
baron is offline   Reply With Quote
