Update and Clarify information and typos. Date 05-23-2013.
The Tv Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select 'Air Channels' ~ 'Antenna Channels'.
__________________________________________________________________
As always , trees and tree leaves , plants and plant leaves , Have a negative effect on reception , multi-path/reflecting , reducing , blocking , Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the DB8 and C5 antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.to
The directions of , North , South West , South , South East , East.
Reason: Deleting 'boiler plate' spam style content
