Old 1-Sep-2012, 6:25 AM   #9
All questions and answers about broadcast tv reception and More.
The following is a Teleview , Recommendation for Digital Broadcast Tv Reception.
Above the roof install a Winegard HD7698P antenna with a KitzTech , KT-200-COAX TV Antenna Booster - Remote Power -Coax Fed preamp and antenna aimed at about 25 degree magnetic compass direction.
Buy the HFS splitter at , http://www.hollandelectronics.com , or , http://www.solidsignal.com.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com , http://www.ronard.com/ychim.com , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com , http://www.kitztech.com.
It is best to mount the antenna in such a manner that there are little to no obstructions in the direction of reception.
