Old 31-Aug-2012, 11:56 PM   #3
All questions and answers about broadcast tv reception and More.
The following is a Teleview - Recommendation for Digital Broadcast Tv Reception.
A UVSJ can Not be used for your reception situation.
WEUX is Very Weak and can require a lot of dollars and a lot of effort , and still not get reliable reception.
Install a Winegard HD9095P antenna with a Antennas Direct CPA-19 preamp aimed at about 116 degree magnetic compass direction.
This antenna system Will Not be connected to the other antenna system.
The 2 Separate antenna system coaxes will go to the location of the Tv and will be connected to a Remote control A/B coax antenna switch , http://www.radioshack.com , #15-1968 , or , http://www.mcmelectronics.com , #32-4425.
The hand held remote control A/B coax antenna switch is Channel Surfing Friendly , press the button on the remote control , change antennas and keep on channel surfing.
For more then one Tv connected use a ,
HFS-2D , 2 way splitter.
HFS-3D , 3 way splitter.
Buy the splitters at , http://www.hollandelectronics.com or http://www.solidsignal.com.
Here are some places to buy antennas and etc. , http://www.solidsaignal.com , http://www.winegarddirect.com , http://www.amazon.com.
