1) Probably. You said it almost comes in with your current setup. Could you describe the setup?
2) No. You will need to do one of the following: Ch 49 Channel master Jointenna If you could find one) or a custom signal combiner or use a simple A-B switch and select that antenna for the games .
If you can snap a digital photo of the view in that direction, it would also help.
Cheers!
