Old 1-Oct-2010, 8:49 PM   #2
Tv Reception
One antenna will likely receive all the channels from the north and north west and that antennas is Winegard HD7084P pointed/adjusted some where between so as to receive all the channels to the north and north west UHF channel 24 - magnetic compass reading 306 and UHF channel 45 - magnetic compass reading 19. In other words turn the antenna so as to 'find a position' that receives all the channels from the north and north west. If this does not do it then there are 2 choices. . First choice - the 2 antenna solution - HD7084P pointed north west and a HD7696P pointed north , use a radio shack remote control A/B coax switch at each tv location to switch between antennas. Mount the 2 antennas at least 6 feet apart on separate mounts. Or choice number 2 - the HD7084P and a rotor - the channel master CM 9521A or the Eagle Aspen ROTR100. http://www.solidsignal.com , http://www.starkelectronic.com , http://www.warrenelectronics.com , http://www.amazon.com . Need more information ? I can provide it - straight up , straight out and up front.
