Thanks. I got the antenna and set it up in the attic (it is huge and barely fit) and the channel scan picked up 18 digital channels including everything I was shooting for, though the weakest ones are breaking up sometimes -- probably because of bad aim (I could easily be as much as 5 degrees off). I'm not sure how to precisely aim it though, since the signals are all digital and reception is pretty much all or nothing. My TV does not appear to have any sort of signal strength indicator. Is there some other trick that can help in this case?
