Old 1-Oct-2010, 8:23 PM   #22
Billiam
Originally Posted by mtownsend View Post
That sounds like a great setup to access channels from multiple markets.
Just keep in mind that if you plan on using a DVR, your antenna can only be pointed at one set of channels at a time. If the antenna is pointed the wrong way while the DVR is trying to record a program, you may end up missing the shows you want.
An antenna rotator is great for viewing flexibility, but it's not so great for unattended recording of programs.
Agreed. Get as much height on this antenna that you are able and it will serve you adequately for the signals you've indicated that you'd like to receive.
