Old 1-Oct-2010, 8:11 PM   #20
mtownsend
Originally Posted by dakrri View Post
I may do 1- winegard antenna, 1-rotor and 1 pre amp.
That sounds like a great setup to access channels from multiple markets.
Just keep in mind that if you plan on using a DVR, your antenna can only be pointed at one set of channels at a time. If the antenna is pointed the wrong way while the DVR is trying to record a program, you may end up missing the shows you want.
An antenna rotator is great for viewing flexibility, but it's not so great for unattended recording of programs.
