Old 1-Oct-2010, 6:54 PM   #12
Tower Guy
Originally Posted by eyemgh View Post
I would like to pick up as many network channels as possible with the least hassle
The problem is, my wife won't tolerate a big antenna.
So, what I'm looking for is the best compromise,
Aim an EZ-HD or ANT-751 at 92 degrees. It would pick up all the stations down to K34DJ that have their azimuth listed in green. Many of them are analog LPTV stations.
http://www.dennysantennaservice.com/...v_Antenna.html
If you consider an Eagle Aspen DB-2 you'd get the same stations except for K13JR.
http://www.amazon.com/Eagle-Aspen-Dt.../dp/B000GIT002
Because the LPTV stations are not necessarily digital, if you want to be sure of HD signals, you will need a rotor or a multiple antenna array.
