Old 1-Oct-2010, 6:12 PM   #9
Billiam
The power lines should not pose a threat to the stations at 345 degrees. They seem to be out of Green Bay. The PBS may or may not be impacted though since that seems to lie to the south. The antenna I recommended should receive Ch. 8 if you run into a problem with 35. Both are to the south though. WPNE is also out of Green Bay and I think this antenna could also get 42 which is the PBS affiliate there.
