Old 1-Oct-2010, 5:49 PM   #7
Billiam
If you don't mind using a rotor then I would recommend the Winegard 7696p to be safe. It probably has a little more oomph so to speak than you need but considering how many signals are in your area, this antenna should give you an extra signal or two just in case you run into a problem with one of the signals at 345 degrees. The PBS station is in another direction and would require a rotor to receive it well or you could use two antennas pointed at 345 degrees and then 188 degrees respectively with an A-B switch.
