Both the primary and translator signals, real CH-12 & CH-23, have adjacent channel interference to contend with. I expect that issue will be more significant than the signal strength and edge path issues.
Try the ANT-751 as @teleview has suggested... You'll either be finished, with KUID keeping you company during cram sessions... Or you'll have real world data on which of the two real channels are more reliable, hence, which to pursue more aggressively.
FWIW: I expect the signal on real CH-12 will be easier to receive. An Antennacraft Y10713 aimed at real CH-12 will put the signal from real CH-13 on the rear quarter of the Y10713, one of it's least sensitive azimuths. The signal on real CH-24 is going to be quite a challenge to null out given that it's much closer in azimuth.
Reason: grammar
