Old 29-Aug-2012, 11:06 PM   #5
Tv Reception.
The following is a Teleview Recommendation for Broadcast Tv RECEPTION.
For reception of the north west group of Digital Tv stations/channels.
For reception of WFFF , FOX and the CW the Tv antenna will be mounted above the roof.
WPTZ-DT REAL UHF Digital channel 14 , virtual number (5.1-2) NBC and This Tv.
WCXA-DT REAL UHF Digital channel 22 , virtual number (3.1-2) CBS and Weather X.
WVNY-DT REAL VHF Digital channel 13 , virtual number (22.1) ABC.
WETK-DT REAL UHF Digital channel 32 , virtual number (33.1) PBS.
WFFF-DT REAL UHF Digital channel 43 , virtual number (44.1-2) FOX and CW.
_______________________________________
WNNE NBC , WVTA PBS , W28DQ Religion , W50DP PBS , are strong signal strength at your location and will most likely be received even though the antenna is not aimed at the Tv transmitters.
Install a Winegard HD7697P antenna with a Channel Master 7777 preamp aimed at about 349 degree magnetic compass direction.
Here are some Above the Roof Antenna Mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com , http://www.channelmasterstore.com.
As always , trees and tree leaves do a real fine job of reducing and blocking Tv reception and so do buildings and other obstructions.
It is best to mount the antenna at a location that has the least amount to know amount of obstructions in the direction of reception.
The Tv's Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
