Old 29-Aug-2012, 7:07 PM   #1
neruo
Help with KTVU (preamp overload)?
Here's my TV Fool report: http://www.tvfool.com/?option=com_wr...e779e7fb0e3979
Here's my setup: I have an Antennas Direct V21 mounted in the attic (for a total of about 12 feet off the ground), attached to a winegard 8700 preamp. The antenna is pointed at Sutro tower (304 degrees). I have about 60 feet of new RG6 coax going to one TV. In general I get very good reception for the channels I want. Except Fox. The main transmitter on RF channel 44 is very weak, and RF channel 48 is very strong (all "signal bars" lit up, 30db+ SNR), but 48 occasionally breaks up. KCSM on RF channel 43 is weak, but usually not weak enough to break up. Other channels coming from Sutro are 4-5 "bars" with SNR of around 22db.
I'm thinking I may have overloaded the preamp.
Here are my questions:
* How do I tell if the preamp is overloaded? How do I know it's not the tuner?
* Does it mean anything if RF channels 43 and 44 are both weaker than should be expected)?
* Would a high input preamp such as Winegard HDP269 help?
Mounting the antenna on the roof is not an option (wont' pass the wife test), and I'm planning on adding a splitter and additional tuner in the future.
Thanks for the help!
neruo is offline   Reply With Quote
