Tv Reception
Simpler yet. 2 Winegard HD7695P 's one pointed at WXSP 15 and the other one pointed at points along between WOTV 20 and WZPX 44 so as to get all of that group of channels , you may have to give up WZPX 44 and have the antenna pointed at 20 and 7. An amplifier can help on the antenna that is pointed at 7 , 20 , 44. 2 separate coax runs with radio shack remote control coax A/B coax switches at the tv locations. The antennas are on the roof and separated at least 6 feet. The real advantage to this separate way of doing it is , No antenna crosstalk , no reduction in signal quality , no reduction in signal strength. I suggest no antenna pre amplifiers to begin with , see what you can get.
