Thread: Changing SNR
Old 28-Aug-2012, 11:31 PM   #15
Tv Reception.
The following is a Teleview Recommendation for Reception of Broadcast Tv.
I was and am not recommending using a preamp and distribution amp at the same time.
I am thinking there are some wiring issues that require correcting.
If using the preamp , install All parts of the preamp (the preamp , the power supply , the power injector) before any diplexers or splitters or anything else that can block the signal or power.
If using the CM3410 distribution amp , install it before any diplexers or splitters or etc.
