27-Aug-2012, 10:47 PM
#7
Originally Posted by teleview
The following is a Teleview Tv Reception Recommendation.
Aim the CM2020 antenna at about 229 degree magnetic compass direction for the reception of ,
WOLF-DT REAL UHF channel 45 , virtual number (65.1) FOX.
WVIA-TV REAL UHF channel 41 , virtual number (44.1) PBS.
WNEP-TV REAL UHF channel 50 , virtual number (16.1) ABC.
WYOU-DT REAL VHF channel 13 , virtual number (22.1) CBS.
WBRE-DT REAL VHF channel 11 , virtual number (28.1) NBC.
W43CO-D REAL UHF channel 43 , virtual number (x) Religion.
_________________________
With the CM2020 antenna aimed at about 229 degree magnetic compass direction are these Digital Tv stations channels also received??
WQPX-DT REAL UHF channel 32 , virtual number (64.1) ION TV.
WSWB-DT REAL UHF channel 31 ,virtual number (38.1) CW.
W47DH-D REAL UHF channel 47 , virtual number (x) PBS.
W14CO-D REAL UHF channel 14 , virtual number (x) ABC and Antenna Tv.
______________________________
Connect the CM2020 antenna to the Tv with No diplexer , No splitters , and only one Tv.
Scan for Digital Broadcast Tv stations channels , what is reception like now??
As always , trees and tree leaves do a real fine job of reducing and blocking reception and so buildings and other obstructions.
That's were I'm pointed. I'm just about 200 to 300 feet lower than the horizon meaning there is no direct line of site. That is why the over size antenna for transmitters only 19 miles away. There are no trees, no houses, nothing in the direct line of my antenna.
