Old 27-Aug-2012, 9:19 AM   #6
Tv Reception.
The following is a Teleview Recommendation for Tv Reception.
The signal strengths are much improved with the antenna at 25 feet antenna height.
Many Digital Tv stations/channels will be received.
Above the roof install a Winegard HD7696P antenna aimed at about 18 degree magnetic compass direction.
For 1 Tv connection use no splitter and no amplifier.
For 2 Tv's connected use a common simple 2 way splitter and no amplifier.
For 3 or 4 Tv's connected use a Channel Master CM3414 distribution amplifier.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com , http://www.channelmasterstore.com.
It is best mount the antenna in a manner that there is the least amount to no amount of obstructions in the direction of reception.
