Tv Reception
Your location has hills , valleys , trees. An Omni directional does not reject mlltipath , as a matter of fact a Omni antenna receives multipath from All directions. Multipath is reflected Tv signals , this not what you are looking for. Your location calls for a Directional Antenna that REJECTS MULTIPATH. The All Band VHF/UHF antenna for your location is the Winegard HD7082P , and a antenna rotor. Or you can go with 2 antenna solution , 2 HD7082P's one pointed at channel 38 and one channel 43. And a radio shack remote control A/B coax switch at each tv location. Mount the antennas on 2 separate mounts , at least 6 feet apart. . Yes you can try the omni antenna and then return it if it does not work. Please note that a omni antenna is close but not totaly omni. The omni antenna may need to be turned to find a position that receives the best.
