Old 27-Aug-2012, 4:01 AM   #15
Tv Reception.
The following is a Teleview Recommendation for Tv Reception.
My concern is coax and connections being the real problem , however if the little distribution amplifier provides reliable reception on the channels go ahead and use it.
Yes you can try it at one end of the coax or the other.
If the other channels are also steady then no need to switch it in and out.
All amplifiers add electronic noise to the signal.
