Old 26-Aug-2012, 11:48 PM   #7
Tv Reception.
The following is a Teleview Tv Reception Recommendation.
Here are some roof top antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com.
_______________
It is best to locate a antenna where there is the least amount or no amount of obstructions in the directions of reception.
____________
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
