Old 26-Aug-2012, 11:06 PM   #6
Tv Reception.
The following is a Teleview Tv Reception Recommendation.
Here is a list of Digital Tv stations/channels that are in the Yellow reception zone.
KPOB-DT REAL Digital UHF channel 15 , virtual number (15.1) ABC.
KBSI REAL Digital UHF channel 22 , virtual number (23.1-2) FOX and MyNetwork.
WPSD-DT REAL UHF channel 32 , virtual number (6.1-2-3) NBC and RTV Retro Tv Network and Antenna Tv.
KFVS-DT REAL Digital VHF channel 12 , virtual number (12.1-2-3) CBS and The CW and Weather X.
For reception of these Easy to receive Digital Tv stations/channels install Above the roof a ANT751R antenna with no preamplifier aimed at about 50 degrees magnetic compass direction.
For 1 Tv connection use no splitter,
___________________________
I see no local PBS station.
The receivable distant PBS station signal strength is weak.
So to Reach Out for KTEJ REAL UHF channel 20 , virtual number (x) PBS.
Install a Separate antenna.
Above the roof install a Winegard HD9095P antenna with a Antennas Direct CPA-19 preamp , aimed at about 222 degrees magnetic compass direction.
For one Tv connection use no splitter.
For 2 Tv's connected use a HFS-2D , power passing 2 way splitter.
Buy the HFS splitter at , http://www.hollandelectronics.com or http://www.solidsignal.com.
_______________________________
The 2 antenna systems Will Not be connected to gather on to one coax.
The 2 antenna systems are Separate systems all the way to the Tv's locations where the 2 Separate antenna systems will be connected to a Remote control A/B antenna switch at each Tv location , http://www.radioshack.com , #15-1968 , or , http://www.mcmelectronics.com , #32-4425 .
