Tv Reception.
Get the RCA ANT111 antenna or Radio Shack has the same type and kind of simple antenna.
Put the antenna in the west window , use a looong coax to connect it to the Tv.
The Tv Must Channel Scan for the Digital Broadcast Tv Channels sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the asir from the transmitting antenna to the receiving antenna.
