Old 26-Aug-2012, 8:12 AM   #2
TV Reception
Your location has Digital Tv stations/channels in All three Tv channel bands to the north east at about 54 degree magnetic compass direction.
VHF low band 2 thru 6.
VHF high band 7 thru 13.
UHF band 14 thru 51.
Examples:
WIWN REAL VHF channel 05 , virtual number (68.1) Weather Nation , http://en.wikipedia.org/wiki/WeatherNation.
WMVS REAL VHF channel 08 , virtual number (10.1) PBS.
WITI REAL UHF channel 33 , virtual number (6.1) FOX.
As always , trees and tree leaves do a real fine job of reducing or blocking reception and so do buildings and other obstructions.
The Big Maple tree Is a obstruction to reception.
It will be best to locate the Tv antenna at a location that has the least amount to no amount of obstructions to reception.
There are No antennas that can see through trees like X-Ray vision.
For the north east group of Digital Tv stations/channels install a Winegard HD7084P All channel antenna with a Winegard AP8700 preamp , aimed at about 54 degree magnetic compass direction.
____________________
At solidsignal the ,
HD7697P antenna is $89.99
HD7698P antenna is $110.99
HD7084P antenna is $88.99
HD8200U antenna is $116.99
Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are some places to by antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com.
__________________________
http://www.3starinc.com/telescopic_masts_and_more.html.
_____________________________
http://www.palcoelectronics.com/pe300.aspx.
The Tv's Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
