Tv Reception.
A Teleview Recommendation for Tv Reception.
As always , trees and tree leaves do a real fine job of reducing and blocking Tv reception and so buildings and other obstructions.
It is best to install the antenna at location that has the least amount to no amount of obstructions in the direction of reception (south west).
The Tv's Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or "Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
