Old 25-Aug-2012, 10:10 PM   #7
Tv Reception.
A Teleview Recommendation for Tv Reception.
The Main groups of Digital Tv stations/channels are to the south west , aim the HDTVa antenna at about 220 degree magnetic compass direction.
Here is how to aim indoor antennas , http://www.kyes.com/antenna/pointing/pointing.html.
Put the antenna in a window that is to the south west type direction.
The Tv Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
____________________________________________
Your location has receivable Digital Tv stations/channels in ALL 3 Tv bands.
UHF band channel 14 thru 51.
Examples:
WKOB-LD REAL VHF channel 02 , virtual number (42.1) http://www.hottvchannel.com.
WABC-TV REAL VHF channel 07 , virtual number (7.1) ABC.
WWOR-TV REAL UHF channel 38 , virtual number (9.1) My Network.
That being the case , All Tv bands , Install a large ALL Band Tv Antenna.
If this is a , house , town home , condo , mobile home , or etc.
Install a Winegard HD7082P antenna with - no preamplifier - Above the roof aimed at about 220 degree magnetic compass direction.
Here is how to aim outdoor antennas , http://www.kyes.com/antenna/pointing/pointing.html.
For 1 Tv connected use no splitter , no amplifier.
For 2 Tv's connected use a common simple 2 way splitter , no amplifier.
For 3 or 4 Tv's connected use a Channel Master CM3414 distribution amplifier.
