Old 25-Aug-2012, 9:00 PM   #10
Tv Reception.
A Teleview Recommendation for Tv Reception.
As always , the starting aim direction is the -> starting aim direction.
Your starting aim direction is 125 degree magnetic compass direction.
The antenna is then rotated to the left and right to find a aim direction that produces the best reception.
It looks the main situation with reception is the trees and tree leaves.
As always trees and tree leaves do a real fine job of reducing or blocking reception.
The antenna mount looks good and strong , I think a 10 foot mast will be Ok.
Here is a 10 foot tripod.
Put a mast pipe in that is 10 feet above the top of the 10 foot tripod and that will put the antenna 20 feet higher. http://www.ronard.com/Tripods%200703/4712.html.
In the fall and winter when the leaves fall off the trees . reception will be much improved.
Trees can also have the tops cut off or cut the trees down.
