Old 25-Aug-2012, 8:54 PM   #1
James
LA CA preamp antenna questions
Advice requested on preamp for antenna.
It took me a long time from the advice on what to install (see this thread: New Antenna in Hemet CA http://forum.tvfool.com/showthread.php?t=3014) to finally select and setup my antenna.
That advice is appreciated.
Now I am getting reception of most channels out of LA on my Winegard HD7084 High Definition VHF/UHF Antenna. Signal strength on my Panasonic GT50 Plasma varies from a high of 86% down to 14% and even zero. When I fall below 40% on some channels and mid thirties on others it will start to break up then seriously and completly drop out when it drops to the 20s and teens.
This has all been great given that I was advised I would only get a few channels and not all the time on those at this 70 mile distance.
When I was watching the Olympics it would drop out intermittently on channel 4. This would happen at completly random times both day and night with early evening being more and more intense drop outs. These would last from seconds to a several minutes. Channel 13 would also drop out with 4. Rarely channel 2 would fail during that time and when it did channel 4 would usually show strong signal with occasional drops. This reception pattern was consistent in both sunny, windy and rainy weather and at night.
Recently we have had a cooling trend here in the Southern Calif region. Also the days are getting shorter and I notice that I get more drop outs and loss of channels in the evening hours lasting till after sunset. Last night, the 24th of August was the worst. I lost 2, 4 while 7 came in strong. I had 11, can't remember if 9 and 13 came in but I also had drop outs in the PBS channels 22, 24, 28 and 30 which has been rare. Another odd thing has been that when 2, 4 and 7 have strong signals the UHF channels are weaker signals and vice versa.
Bottom line, currently I can watch most channels just fine all day long and until last night in the evenings as well. Still losing several minutes at a key play in sports or the peak of drama hurts.
I have read a bit on preamps and am confused what to choose or if one will even resolve the problem. If the signal goes away completely obviously I will receive nothing. But last night it would log on just enough to pixelate the whole screen and freeze image or judder for minutes at a time. Not watchable.
Here's the specs on my setup; The antenna is on a mast at a height of 19' pointed at or a few degrees south of 299 ° . I have a 15' quad 6rg cable running from the antenna 75 ohm down lead to a groundblock splitter. It is a two out splitter at 5 - 1000Mhz. The open side of the splitter is not capped. I am running a cable that I think is rg11 dual shield because of it's thickness compared to rg6 at approx 50' along underside of metal carport roof and in through a metal sided window to a coupler and then 6' of the rg11 into a splitter for cable/antenna (Mhz unknown. It came from the dollar store. It works). Finally I have 6' of quad rg6 plugged into the TV from that. That comes to 77' of cable run with two splitters.
My estimation of signal loss lead me to think I should get the WInegard preamp ap8275 with it's29db boost. Guidelines say that the TV has AGC and that makes me wonder if it won't negate the boost signal enough to overcome the weakness. Also when I have an excellent signal will the boost be a risk to my TV electronics? I have attached a pictures of the antenna as well as the skyline it is pointed at. You will see a tree approx 100' away partially in the path. It seems to me it is not having an effect on signal quality.
Channels I get: 2,4,7,9,11, 11.2 FoxSD, 13, 20*, 22, 24, 28, 30, 46, 50, 51
*lists but no reception.
Channels I'd like to add KTLA 5, FSFV 6, KFLA 8
Feedback on what might be causing the signal loss when it happens as well as suggestions on my preamp choice invited.
James is offline   Reply With Quote
