Old 25-Aug-2012, 3:41 AM   #2
Tv Reception.
A Teleview Recommendation for reception.
All Digital Tv stations/channels requested and many more will be received.
Install a Winegard HD7696P antenna above the roof aimed at about 180 degree magnetic compass direction.
For 1 Tv connected use no splitter or amplifier.
For 2 Tv's connected use a common simple 2 way splitter , no amplifier.
For 3 Tv's connected use a common simple 3 way splitter , no amplifier.
Here are some antenna mounts , http://www.ronard.com/9099011.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com.
As always trees and tree leaves do real fine job of reducing or blocking Tv reception and so do buildings and other obstructions in the direction of reception.
Mount the HD7696P antenna where there is the least amount or no amount of obstructions.
