Old 24-Aug-2012, 9:03 PM   #4
Tera
Antenna behind the trees, will I get the channel?
Hi, Thanks folks for the suggestion.
I am aware that the higher and the less obstruction means better reception.
Between my location and CN Tower it is absolutely LOS, except for 3 -4 layers of tree in between These trees are tall. Even with a rooftop installation these trees will still bloc the LOS.
Will these trees degrade the signal significantly, so I cant get reasonably good reception?
Thanks
Tera is offline   Reply With Quote
