Old 24-Aug-2012, 4:19 PM   #17
If you want reliable reception year-round, the tree-top will probably have to go. Otherwise, you'll likely encounter reception difficulties particularly during the time of year when the tree is leafed out. It will be worse when the tree is wet and the wind blows.
Is it a deal killer? Some folks still get good reception even through trees while others don't. We recommend trying to avoid the problem whenever possible.
Do keep the antenna away from the smoke. Creosote accumulation will turn acidic when it rains and will cause corrosion to accelerate.
