Old 24-Aug-2012, 2:57 PM   #15
BlueRidgeVA
Trees directly in the path ...
Hello. Thanks again for all of your valuable help. I checked the 77 degree azimuth this morning, and was surprised where I was pointed. I've attached a photo showing my situation. The 77 azimuth passes through the tree just to the right of the chimney. I did not get on the roof to see what the line of site would be, but imagine it is straight through the top section of the tree. It's kind of a cross-slope direction, but the ground is dropping away so more distant trees should not come into play.
Does this look like a 'deal killer' to you?
BTW - the 111 azimuth is more straight downhill, with about the same tree situation.
Another quick question. We use the fireplace a lot in the winter. Any issues with bolting a mast to the side of the chimney?
Thanks again everyone.
BlueRidgeVA is offline   Reply With Quote
