Old 24-Aug-2012, 3:35 AM   #2
Tv Reception.
A Teleview Recommendation for Tv Reception.
For reception of the Canada and USA Digital Tv stations in the Green to somewhere in the beginning of the Yellow reception zone install a Winegard HD7696P antenna with a Antennas Direct CPA-19 preamp , aimed at about 180 degree magnetic compass direction. the HD7696P antenna is required to be located in a manner that there is the least amount to no amount of trees and tree leaves or buildings or other obstructions in the direction of reception.
________________________________________________________
Your location has Many Canada and USA Digital Tv stations/channels that can have reliable reception to the , south west , south , south east , in the Green and Yellow reception zones , down to at least WNYO-TV channel 49 MyNetwork , with a large antenna aimed at about 180 degree magnetic compass direction.
To reach out for reception of that many Tv stations requires a Winegard HD7698P antenna with a Antennas Direct CPA-19 preamp.
The HD7698P antenna will need to be mounted in a manner that has No trees or tree leaves or buildings or other obstructions in the direction of reception.
Shoot over the tops of the trees or around the trees.
Some common roof top antenna mounts are , tripod antenna mounts , eave antenna mounts , chimney antenna mounts.
Here are places to buy antennas and etc. , http://www.saveandreplay.com , http://www.trentondistributors.com , http://www.canadapost.ca/shopper , http://www.amazon.ca , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com.
___________
For 2 Tv's connected use a HFS-2D , 2 way splitter.
For 3 Tv's connected use a HFS-3D , 3 way splitter.
Buy the HFS splitters at , http://www.hollandelectronics.com , or , http://www.solidsignal.com.
The HFS splitters are high quality Power Passing splitters that pass power to the preamplifer unit out at the antenna.
Common splitters that pass power through input and one output will also work.
_____________________________________________________________________
