Old 23-Aug-2012, 5:46 PM   #4
Tv Reception.
A Teleview Recommendation for Tv Reception.
The Digital Broadcast Tv stations/channels are Very Weak at your location at 20 feet antenna height.
I suspect that No Digital Tv stations/channels will be reliably received with a Tv antenna inside the building.
1 channel is in the yellow reception zone and is Very Weak.
Then down in to the Red reception zone and the channels are Even Weaker Yet.
The Digital Broadcast Tv stations/channels at , 77 degrees true / 86 degrees magnetic compass direction , look to be all in the UHF TV band of channels 14 thru 51.
Install a Winegard HD7698P antenna with a Antennas Direct CPA-19 preamp aimed at about , 77 degrees true , 86 degree magnetic compass.
For 2 Tv's connected use a HFS-2D , 2 way splitter.
For 3 Tv's connected use a HFS-3D , 3 way splitter.
Buy the HFS splitters at , http://www.hollandelectronics.com or http://www.solidsignal.com.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv channels are transmitted through the air from the transmitting antenna to the receiving antenna.
As always , trees and tree leaves do a real fine job of , reducing or blocking Tv reception and so do buildings and other obstructions.
It is best to locate the antenna at a location that has the least amount of or no amount of obstructions in the direction of reception and higher antenna placement is usually the best.
