Old 23-Aug-2012, 5:03 PM   #1
Tera
Richmond Hill, ON Canada, Bayview and 19th
Hi friends,
I am newcomer here.
TV Fool:
http://www.tvfool.com/?option=com_wr...99009f1d02712a
High elevation, used to be able to see CN Tower (south) from the ground level and better from 2nd floor. Trees are getting bigger blocking my view.
So, behind 2 - 3 layers of trees (the closest tree is 60 feet from planned antenna location) I have Line of Sight to CN Tower.
Need advice:
1. For channels south of my location, will an outdoor antenna behind these trees work well?
2. I would avoid roof top or tower installation.
3. What antenna do I need. Preferably the DIY one, 12 feet above the ground, facing CN Tower (south, Line of Sight).
4. For a VHF & UHV combined antenna, do I need to run two coax cables (1 for VHF,1 for UHF) from antenna to TV?
5. Can a coax cable from antenna be split to two TVs, so each TV can tune to different chanel.
6. Where are the closest place supplying OTA antenna?
Thank you. Sorry, too much question
Kindly waiting for your expertise
Tera is offline   Reply With Quote
