Old 22-Aug-2012, 4:11 AM   #2
Tv Reception.
In the attic install a Winegard HD7696P antenna aimed at about 73 degree magnetic compass direction.
The HD7696P antenna is a , heavy duty strong and sturdy antenna.
Use No preamplifier.
Yes use a Channel Master CM3410 distribution amplifier.
Most attics have a electric outlet to plug a Channel Master CM3410 distribution amplifier into.
For 1 Tv connection use no splitter.
For 3 Tv's connected use a common simple 3 way splitter.
For 4 Tv's connected use a common simple 4 way splitter.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.channelmasterstore.com.
As always,
Metal backed insulation in the attic.
A metal roof.
Thick roof tiles.
Solar Panels.
Stucko with stucko Wire on the attic end walls.
Trees and tree leaves.
Other buildings or other obstructions.
All do a real fine job of reducing or blocking Tv reception.
___________
