Tv Reception.
One more issue.
W47DY REAL Digital UHF channel 47 , FOX TV.
Is signal strengths of minus - 11.8 NM(dB) at 20 feet antenna height.
Minus -10.1 NM(dB) at 40 feet antenna height.
Minus -7.5 NM(dB) at 60 feet antenna height.
60 feet is the best by a small amount.
The signal strength numbers put the reception with in reach , it will be interesting to see how the reception works out.
I think the station will be reliably received.
