Tv Reception.
The Tv stations that you will receive are from about 57 to 102 degree magnetic compass direction , east north to a little past east , east and a little south.
Form 20 to 40 feet there is not much improvement in signal strength , even so it Is Better to have the antenna higher then 20 feet.
There is a little better improvement of signal strength at 60 feet.
If this were my house I would shoot for 40 feet or higher.
I am changing the antenna to a bigger antenna , HD7698P antenna , a bigger antenna means more reception.
At first I recommended a HD7696P antenna because I thought you might put the antenna in a pine tree , the HD7698P is smaller and would not whip around as much in a tree as a HD7698P antenna would.
So now that you have a clearer view to the east north to east south. I am recommending the HD7698P antenna.
Mount the HD7698P antenna up high and I believe the listed Tv stations will be received.
It is best to install/mount the antenna where there is the least amount to no amount of obstructions in the direction of reception.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
