Old 21-Aug-2012, 10:16 PM   #3
Tv Reception.
To see if signal strengths improve with more antenna height , please make 2 more tvfool radar plot map reports , 40 and 60 feet antenna heights.
The Digital Tv stations/channels that you are installing a antenna to receive are.
WLOS REAL Digital VHF channel 13 , virtual number (13.1) ABC and MyNetwork.
WUNF-TV REAL Digital UHF channel 25 , virtual number (x) PBS.
W08AO REAL Digital VHF channel 08 , virtual number (x) CBS and Me Tv.
W23BQ REAL Digital UHF channel 23 , virtual number (x) Religion.
WUNW REAL Digital UHF channel 27 , virtual number (x) PBS.
W08BP REAL Digital VHF channel 08 , virtual number (x) CBS and Me Tv.
W11AU-D REAL Digital VHF channel 11 , virtual number (x) NBC and This Tv.
_________________________________
W02AG , W08AO , WSPA , W08BP , are all the same CBS and Me Tv.
WUNF , WUNW , W19HK-D , are the same PBS.
http://www.rabbitears.info/market.ph...callsign=69389.
______________________________________
Install a Winegard HD7698P antenna with a Antennas Direct CPA-19 preamp , aimed at about 65 degree magnetic compass direction.
Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/Tripods%200703/4712.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com/tree_adjust.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com.
Here is a , Light Weight Aluminum , Free standing , No guy wires , Lay Over Tower , Do antenna mounting and adjustments standing on the ground. http://www.palcoelectronics.com/pe300.aspx.
_______________________________________
For 1 Tv connection use no splitter.
For 2 Tv connections use a , HFS-2D , 2 way splitter.
Fo 3 Tv's connected use a , HFS-3D , 3 way splitter.
http://www.hollandelectronics.com or http://www.solidsignal.com.
